Ok, what am I missing. I just want nodes to use a registration line to a server. All seam good, but I am not seeing nodes IP address or Port. The following is the code.
[general]
context = default ; Default context for incoming calls
allowguest=no
allowoverlap = no ; Disable overlap dialing support. (Default is yes)
bindport = 5060 ; UDP Port to bind to (SIP standard port is 5060)
bindaddr = 127.0.0.1 ; IP address to bind to (0.0.0.0 binds to all)
srvlookup = no ; Enable DNS SRV lookups on outbound calls
; Note: Asterisk only uses the first host
; in SRV records
; Disabling DNS SRV lookups disables the
; ability to place SIP calls based on domain
; names to some other SIP users on the Internet
[1800]
type=peer
host=dynamic
sercret=123456
username=KG5RDF
disallow=all
allow=ulaw
transfer=no
Output in CLI:
Name/username Host Dyn Nat ACL Port Status
1800/KG5RDF (Unspecified) D 0 Unmonitored
1 sip peers [Monitored: 0 online, 0 offline Unmonitored: 0 online, 1 offline]
I am needed a registration server that will take the stand node registration line:
register => 1800:12345@×××.×××.×××.×××
I noticed sip does this. It shows 1800 as a peer, but does not show 1800 ip address or port. I was going to parse the file to update the database extnodes.
Yes SIP does this for SIP devices.
IAX does this for IAX devices.
What is the device ?
Nodes are IAX
SIP devices are not going to communicate with IAX devices. Different protocol.
You can register nodes in rpt.conf file under [NODES]
I was looking for only inbound sip from remote node registration line. I gotten a node to show its connected as peer using remote node registration line, but no ip or port shown. It was a thought to try. Do not want to use [nodes] in rpt.conf. I need a real time registration server. I need to update the database as ip’s change and if they are connected to the system. It about 100 nodes. I manually created download files, for the server to pull and update astdb and extnodes. I need to automate this process. I rewritten the server code and system is up and running. Just need to do the registration server.
Yes, three servers. I did get the registration server working and seeing ip’s, callsigns, and ports via iax. Will revisit the sip later today for servers.
