I am running ASL on a two Raspberry pi 5 with Debian/Bookworm. Following Alan’s instructions on github.
They both have been running great. Great instructions and easy to follow.
I tried to upgrade 1 ASL node from OS 1.6 to 6,6 and it breaks ASL. I also tried to download a new Raspbian image 6.6 and went through the process again and the DAHADI section fails.
So I am back to 1.6 were it works fine again. Has anyone done the update to 6.6 and have it working?
I am not a linux guru and not sure were to go or how to fix it to make it work.
I’m a bit confused by your OS 1.6 to OS 6.6 comments.
Where are you getting your images?
Are you using the Raspberry Pi Imager?
What image are you choosing? 64-bit? 32-bit? Lite? Full?
Also, if you “apt update; apt upgrade” and end up with a new kernel installed on your device then you must (a) reboot and (b) start the asl-install process over from the top (Setup, …).
73,
Allan
p.s. earlier today I pushed an update to the project so either “git pull” to update your downloaded copy of the repo or clone a fresh copy.
I use PI-Imager
Raspberry pi OS 64 bit
Using the full version.
The first install with 6.1 went well with out and issues.
After I receive your reply I will start from scratch and go through the process again.
I have two nodes working back on 6.1 right now.
I will make a back up copy from 6.1 and restore after I get 6.6 working.
Allan, I’ve used raspbian on Debian 12 with a pi 4 and it works great. I’ve done it with a a pi3 and it works but lags a lot. Right now I’m running ASL on a Dell Wyse mini computer on Debian 12 using instructions from your github, also running a sound interface. It works great.
I started from scratch again and had the same result with DAHDI Giving me an error. I am attaching the /var/tmp/build-dahdi.txt file that the error has referenced. build-dahdi.pdf (43.4 KB)
Perhaps someone with a Pi 5 and Raspberian 6.6 will chime in here,
But this is very new OS (days old-march 12 2024) Unless you have some older beta.
It i the kernel/headers that breaks DAHDI
But I might add that if you were trying the version with full desktop, perhaps try the skinny minimal version.
I would suggest you stick with the working 6.1 unless you want to hammer the issues out.
I’m not sure what is to be gained.
Perhaps someone who has worked it out will chime in. But I doubt many with a Pi5 are even aware of the new Rasbian 6.6 yet.
Thanks Mike, I am good staying with 6.1 for now.
I will try a more bare down version maybe tomorrow… But I am content with 6.1 for now.
Will let you know on the scaled down version when I do it.
I am also booting from NVMe M.2 SSD drives. Pretty cool faster.
Like to have the latest, but I know when to stop and wait.
Yes, changing storage on a pi helps, and even more with later Pi’s.
Class 10 SD cards are not going to boost performance any on a Pi 3,4,5 compared to a good SSD on a usb3.
And Most of buy the sd cards on ebay/amazon where they lie about the class they are and get away with it. A True class 10 is not all that bad. But not near as good as USB3/SSD.
And we hams always buy the cheap stuff LOL
Look forward to the result using the skinny version.
